The MNSHOC Pic thread.
troll11911
big lake, mn
rear rotor was missing about 1/4 inch on the back side, yet it has brand new brake pads and he couldn't figure out why it was making a grinding noise!!!! tryed to put a system in it, so he clipped off the harness for both the deck, and the factory amp and tryed to hard wire them so no I have to get new harnesses and fix that....ashing in the center console, put a cone filter on using electrical tape....there is more I am sure
whiteman_01
Well-Known Member
Hastings, MN
Wow. Sounds like you need to spend a good day at the junk yard. When i got my 93 it was also missing all the connectors for the amps in the trunk. I just went to the yard and back halved the whole stereo harness. They actually just gave it to me for free. I soldered it in and all is well.
troll11911
big lake, mn
the only yard with one around is riteaway auto, and they are trying to rape me dry on everything. they want 30 dollars just for the seat switch, 50 for the muffler....
troll11911
big lake, mn
dorman ac bypass pully. I have one on my 97 cutlass supreme and it works great...but my ac compressor is just thrashed, no chance of fixing it....battery acid all over it, from previous owner, and well it is bad...and there is no way I am spending 200 dollars on a new compressor.
the4biddendonut
Hurry up meow.
Elk River MN
The dorman bypass is the same thing. The quality of the pulley is terrible, and on my ATX the pulley didn't even line up with the rest of the accessories.
whiteman_01
Well-Known Member
Hastings, MN
You could just pull the compressor, gut it, and bolt it back in to keep the strength in the bracket. Then just get a shorter belt for the front.
troll11911
big lake, mn
I am going to pull it out today, and see if I can rebuild it...but either way, if I have to, I will still use the bypass pully atleast for the time being. I need it running! also, is there anyone on here that has a muffler? passanger side?
troll11911
big lake, mn
I have finally fixed everything....only thing left to do is sand and paint the whole car and fix some rust...I got the compressor for 25 dollars from a guy in mora, and replaced the entire brake assembly in the driverside rear. took pictures of a sho motor in the junkyard and the put all the vacuums where they were supposed to be, tore off the ghetto intake the kid had on there, and re-did it....uh cleaned the interior fixed all the broken stuff from the kid I bought it from,....still need a few small pieces replaced from him burning them with cigs,....but it all it is a totally different car than what I bought.
SHO1
Coke Is It!
The State Of Hockey
What color int? I have some spare grey parts.
whiteman_01
Well-Known Member
Hastings, MN
Speaking of gray parts, i have door panels, b pillar panels and full good carpet if anyone wants it.
Sammy~D
Wrench Whore
Anoka, Minnesota
The New 94 ATX Getting The **** Worked Out Off Her Lots Of Problems
L 3d69b09246754096808ab0abe4605dd0
L 8e681b9ed6724e12b744792943dee628
L 67355245cfd8497db74dc7398581328f
1992 Sho Getting Turbo But not very fast at that (over 1 year so far) Thanks Joe this car is getting the 600 i bought it from you for
L 279cf51c6e6fc367d9d402b834c5d4a9
L 7d6a0d5c704e4b0b4d69f66633feca70
L 8dea3c0ba0abed157799077f286e8cd5
Sammy~D
Wrench Whore
Anoka, Minnesota
here are some of the srt i got it mostly like you see it i put on alot of the dress up and intercooler but it is a really nice car for sure
Stock S2 SRT Before i even bought it
L de7c846f078544229417a724c834f7b1
L 72e55750cb8246fc92211d45d52d8572
L edffee9e52bd415f9e127b69888b72e6
L b74a068e60b2495a8197d4fdd53f8f49
L ed9def9e30b34c5e95c32fc46f78b391
