The broken Y-Pipe blues...any ideas?
NWGRN94MTX
Vancouver, WA U.S.A.
Brandontw said:
i think trueSHO is going to hook me up with an old stock one that he had laying around and hopefully i can get it welded on for 200 or so.
I really dont even care about performance anymore... my car has like 290000 miles on it and runs like a one legged wombat, so i dont think a stock y pipe will be a big drag on it. As long as i can quiet it down a bit so it will get me around pleasurably for a while more, i will be happy.
I think i will replace my O2 sensors while im at it... any recomendations for some cheap ones that dont suck?
do you think they will be able to fit the old stock y pipe to the aftermarket exhaust OK?
Dude,
If it's a Y-pipe, NOTHING will need to be welded. It's bolt on. Matt, known on the Forum here as "Dr Evil" lives in Sparks. PM him and ask him for help before you get bent over by a shop that will take advantage of you.
Brandontw
Reno, NV
dude, its all one peice from where it bolts onto the headers, i would love to do it myself but i dont know if its possible.
NWGRN94MTX
Who was the ***** the welded the rear Y-pipe ****** to the exhaust pipe ******? I'd slap them. :biggrin:
ViPER1313
Ijamsville, MD
Must be the same idiot who did it to my car before I got it :shrug: I really wish I took a picture of that after the pipe cracked in two.
Brandontw
Reno, NV
that would be mister Z's exhaust is sparks, Nevada - they did a shittty job on this whole thing...i dont know how much the guy i got it from paid for it - but it was too much.
im thinking of going ahead and try doing the install of the new y pipe myself anyway though... i will have to cut the exhaust where the new y pipe will meet it and then i will put the y pipe inside of the old pipe becasue it is going to be smaller, and try a muffler clamp to clamp it down and hold it together, then im going to borrow a freinds mig welder and try to weld it up myself.
Th O2 sensors are in the y pipe right?
i dont know how i will jack my car up enough to get under it good...
NWGRN94MTX
Go over there and kick him in the package. If he doesn't know what he's doing, he shouldn't be business doing exhaust systems. :evilgrin:
I would weld on a new ****** to the exhaust and make it correct again. You will need a new doughnut and the spring bolts, but it will be correct.
Good luck
Yes the O2 bungs are in the Y-pipe, precat.
Brandontw
Reno, NV
NWGRN94MTX said:
I would weld on a new ****** to the exhaust and make it correct again. You will new a doughnut and the spring bolts, but it will be correct.
Good luck
your talking about the part with two bolt holes right? where would i get the ******? and my pipe is a 2.5 or 3 inch pipe also..a stock ****** would be no bueno right?
im also worried that the flex pipe may be no good, or worse yet, it may be placed right where I will need to cut to fit the new y pipe in
NWGRN94MTX
A new flex pipe will work as long as it has a coupling that will match up the the MTX Y-pipe so you can unbolt it. Maybe someone can chime in here with a part number for you on one that will work with a 2.5" pipe. Since you have a 2.5" pipe now, if you going to order a new Y-pipe, I would get either the SHO Shop's or a Performance Plus, which Doug from Ford Performance Specialists now sells. F.P.S. is a Forum sponser and has a banner link to there site from the forum. These are both 2.5" mandrell bent Y-pipes.
jedhead
westminster,ca
Instead of the ****** and springs I would go with a flex pipe like the ATX has. I installed one in my exhaust it took care of my frequent doughnut replacements.
I used Bosch O2 sensors I purchased at autozone part number 13942.
Bob
NWGRN94MTX
Brandontw said:
BTW..do you have any suggestions for O2 sensors?
Motorcraft E97F-9F472-CA or the Bosch equivilent, I think it's a 258?
Don't get a "one size fits all" O2 sensor. Some parts store sell you those saying they will work for the application. They do, but not all that well.
Brandontw
Reno, NV
Bob
im going to try to just to us ethe current flex pipe
how much were those o2's?
