Tests done, looking for advice
Monterusto
NY NY
This morning i ran fuel pressure tests
1. hooked the gauge cycled the key 7 full times-
17 psi. then released pressure (on gauge).
2. 2 min. @idle - 21psi. released pressure
3. 2 min. @idle /w FPR and intake plugged- 22psi. released pressure. reconnected FPR.
4. 2 min. @4500rpm 20 psi.
Ran codes. codes were cleared a week or two ago. idle was reset earlier today.
koeo- 11/ 63,66,91-ignore 63 tps was unplugged for a min.
koer- 12,26,41,91,25
cylinder balance test gave 3,4,5,6 ( tested 2 weeks ago and got 4 and 6
I would appreciate anybodys assesment of these results.
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
You have a seriously low Fuel Pressure problem.
How old is the fuel filter? Does the pressure drop down if you open the throttle, or jump up, or stay the same?
