Tach Problems
shotyme03
Detroit, Mi
Tach drops when i get into the gas somebody told me to check the dis module. WHERE IS THE DIS MODULE
40BelowSummer
Puerto Rico
stand on the passenger side of the car facing the front passenger tire and antenna with the hood open. it is located on the passenger side of the intake manifold. Its mounted on the side of it and reads Motorcraft DIS. It has 2 connections (wiring harnesses) attached to it, it is grey in color and is the size of a audio cassete or something.
autobahnsho
SHO Victim
NY for now, WY for real
Right between the two large red circles.
Sorry JDLangevin, I stole the pic off the www.shophoenixproject.com maintenance section.
This module gets it's power from ground. On the rear passenger corner of the intake there is a bolt to the intake and a wire. Make sure it has a good connection.
Also check that the module itself is mounted right- and that the plugs are on good.
