Tach Light
Fordlover96
Virginia
Alright guys, about half of the back light for the Tach on my 93 just went out. So I looked that up and found this, http://www.shoforum.com/showthread.php?t=58663. So do i just follow the directions and then remove actual gauge faces or are the light bulb in the very back requiring me to remove the entire gauge cluster? Thanks so much!
btw, you need to remove the cluster to get it open to pull the gauge faces off.
but, you just need to pull the cluster out far enough to get behind it to change the bulbs from the back side.
