switching a powerdyne over to a vortech
Revere sho
Revere MA.
ey guys i just got a 94mtx sho with a 9psi supercharger in it and just wanted to if its extremly hard to switch powerdyne setup to a vortec set up. also if it is possible roughly how much would i be shelling out? thanx
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
I have both styles, and they are totally different. The only thing that would be common to both is that the battery relocation, larger injectors, and maybe the rough tuning.
The Vortech obviosly uses a different S/C, brackets, and piping, but you will also have to tap into the oil system and pan since the Vortech is oil lubricated and the Powerdyne is not. If you want to go to a Vortech set up, there is a group buy on for the piping and brackets in the group buy section.
Personally, I would just stay with the Powerdyne unless you were planning on 9psi+ boost levels.
Either system will give you lots of power and enjoyment.
- Mike
dan.delargy
