suspention question 2
thecrew2999
3.2 MTX SHO
Harrisburg/WilliamsportPA
ok i posted a thread before here http://www.shoforum.com/showthread.php?t=74165
and well i got more to add because i had the car out last night. im pretty sure what it might be but id like to be certain.
i noticed something else when driving it. when you get to the top of the rpms in just about any gear the car seems to shoot side to side like when the engine gets to full power it pulls and cant seem to kepe straight. im assuming this will have a lot to do with the strut rods and last time i checked i got some cracks on the bushings.
olny other thing im worried of is if you just cruising and turn side to side in a quick manor it seems to have "lag" so to speak then it turns and im sure the rear end links are the problem since they seem too long and are kinda going backwards at a angle. should these be the cause of this problem or should i just go ahead and replace all the bushings on the car now and be done with that.
also the sway bars are 24/26 and its a 95 (once atx) mtx.
i got a few bugs left to work out but the car has been going good for me, long slow process, just havent had much time for it lately.
thanks:thumb:
