Surging is one of the symptoms of a IAB valve not working well. A good cleaning of an IAB after it is removed from the intake should help. You need to be able to clean the piston inside the IAB valve and the only way you can get to it is after you remove it.
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
