Sunroof seal is bad....
GreenBird
Barre, Vermont
it's all crushed and doesn't make a good seal with the roof when I close it. gets noisy on the interstate, and I spend alot of time on there.
Does ford still carry the seal? anyone but ford have it? easy to install?
Gez89SHO
LEGO SHO
NE Philadelphia, PA
It's a Webasto sunroof, I would call Webasto and see if they have it available. The seal is glued on, so the old one has to be cleaned off. This means you night have to take off the sunroof. To remove, first open sunshade and tilt glass up. Then move the "halo" by loosening the front 3 screws, then sliding the halo back. You can then remove the 3 screws on either side of glass and remove glass.
Also, there have been numerous posts about this, I would search both here and the old topica list (www.topica.com/lists/shotimes/read) for more info.
