Sunroof Doesn't Work - Clicking Nosie From Dash
edwerd
Brooklyn, NY
Hey all,
Sorry to bother with such a simple problem but I don't have the equipment or experience to correctly diagnose the issue.
I recently replaced my faulty sunroof switch with a perfectly working one provided by one of you awesome shoforum members -- however a few weeks later I decided to remove the console again to epoxy one of the metal brackets which was falling off and after putting it back in my sunroof stopped working again!
I hear a clicking noise coming from the dash (first time I heard this relay click when depressing the button) which I've read would indicate a bad relay, but others on this forum have also mentioned it could be a bad motor or, once again, switch.
Could anyone tell me if the moonroof relay clicking indicates a bad relay or could also be caused by something else? i.e. bad motor or switch. I'm really hoping it's the relay.
Thank you for your help,
Eddie
hawkeye18
Sorta cares
Norfolk, VA
umm... I can't help you with that, sorry, but I can tell you that the only way you're going to permanently mount those brackets onto the plastic part is by heating the bracket up to about 500 degrees. seriously. Put it in a flame 'til the rust starts burning off, then (carefully) stick it into the console. Push hard; it'll melt the plastic under it. It'll never come off again, I can promise you that (unless you moved it while it was cooling).
ManySHOs
South Jersey
Actually, JB Weld works great. Granted, I've only had it on for 100K miles and 10 years... :)
Ian
edwerd
Brooklyn, NY
Hm, I don't know about that. The epoxy I used is pretty strong, shoud last the life of the car.
SHO SPD
SHO member #480
Naples, Florida
A working relay will click. Are you sure you didn't accidentally disconnect the switch when you were reattaching the console?
edwerd
Brooklyn, NY
Ah okay, good to know. Before putting the console back in place I attached the switch to the harness and the relay was clicking even then. I didn't wiggle the wires around to see if maybe something was loose or re-seat the connection as I was in a rush but I'll go do that once it stops pouring here.
Thanks, I appreciate it.
edwerd
Brooklyn, NY
I removed the console again and inspected all the wiring, looks great. Plugged and unplugged. The switch isn't cracked or anything. Any ideas?
I'm getting worried it's the motor, but it has never given me any issues before. Everything worked until I removed the console. I didn't pull or tug any wires.
Bah.
Storm-Chaser
Shit Louis
Since the moonroof console is off, did you try applying power directly to the motor to see if it works ?
:burnout:
edwerd
Brooklyn, NY
:burnout:
I would of course like to try that but I'm not sure how to safely go about it. What source of power should I use and which wire do I apply it to?
edwerd
Brooklyn, NY
I just ordered a new relay which I'll replace and I'm fixing my old switch which cracked to see if it's one of those. I don't know what I should use to power the motor so I can test it.
thecrew2999
3.2 MTX SHO
Harrisburg/WilliamsportPA
clicking replay does mean it is working usually... but i have found relays with bad connections from old age im guessing but anyways they can still be bad only way to know for sure is multimeter
edwerd
Brooklyn, NY
Thanks. I fixed my old switch and still no luck. The relay still clicks when depressing the button but the motor doesn't budge. All wires and connections are in great condition, along with the motor. Still not sure what the problem is. Waiting on that relay to arrive.
If I replace the relay and it still doesn't work I'll just bring it somewhere and have everything tested -- I don't have a multimeter.
edwerd
Brooklyn, NY
Perhaps, though I really doubt it. Car sat in a garage most of it's life and is very low mileage. Without anything to test it I'm not sure at this point. If replacing the relay doesn't work, I'll just buy a new motor. If that still doesn't work, then at least I have a new motor!
jruss1601
Southwestern PA
I'm having the same problem now. I can tell you what i did. Went to the junkyard and got another moonroof motor. They tested it before i left with it. It worked. I changed my old one out, put this new one in and nothing. Someone here told me to grease the tracks. I was going to until my dad came over and said that can't be the problem. So he checked it out and said the clicking relay could be the problem. I took it out and am going to look into getting another. Afterwards he said lets try the putting power to the motor. So he was going to attach a jumper cable to the negative side of the battery and the other end touch to the moonroof motor. We tryed it but then realized we had taken the relay out. So nothing happened. I might try reattaching it later and trying it again if you guys say a clicking relay does work. Does that mean it is working because its clicking or that it could be faulty and still click?
Goodluck man. If you figure it out let me know
jruss1601
Southwestern PA
also, was your relay made by BMW? Mine was. I found that .......interesting
edwerd
Brooklyn, NY
Sorry, for some reason I didn't get notification of all these new replies until now...
Yup, I replaced the relay and reseated all the connections to the motor again and it works great now. I think I only paid $10 for the relay, and yes it was made by BMW. ha
Thanks guys,
Ed
