Subframe Recall
FrOsTyShO
Lemont, Illinois
I looked on my passenger side front foor, pulled up the carpet and I have the hole right there for the subframe nut. I can see the nut and bolt, but the little tabs that hold the bolt are still there. So my question is, if the little tabs are still there and don't look like they've been touched, is the subrame bolt recall done on my car or not?
KentuckySHOoff
Bardstown,KY,
i don't have an answer to your question but my sub-frame bushings failed me while i was moving and it was very very nasty. motor and tranny hit the groung and the steering was shattered.
good luck.
projectSHO89
SHOless In St L
FrOsTyShO:
Yes, it has been done.
Steve
<small>[ June 01, 2003, 01:43 PM: Message edited by: projectSHO89 ]</small>
91 SHOplus
Sholess 4 Now
North Jersey
SHO--ripper:
Have FORD run your vin and they will tell you if it has ever been done.
Definately have Ford run your VIN #. Even if it was done, you'll also find out about any other outstanding recalls that you may need to have done.
