timbo
I have a 1996 SHO and at low speeds and when the O/D is off, you get a thumping back and forth when going on and off the gas.
It appears to be a solid thunk and you feel it and can sense the rocking motion. Which should I look at Subframe mounts or motor?
Thanks in advance
PS, the subframe mounts (rear) were somewhat loose, I tighten, but did not seem to make a difference. I also did the "in gear test" and the engine seems to only move an inch or two.
But under load, it's a thunk!
Thanks in advance
