Sub Size?
Her94SHO
Texas
My '94 JBL Premium sub surround is toast. Does anyone know the size of the factory sub or an adequate bolt on after market replacement?
Sammage
Wichita, KS
I believe it's a 6 1/2" sub (according to SHOtimes), be sure to use at least a 4-ohm sub or you will lock-up the amp (my friend did to his :( ) The stock amp should put out 85 watts RMS. Let me know if you have any other questions. I think CincySHO sells used stopck subs in good condition: http://209.217.44.39/used.htm
Later, Sam burn_out
Chris Benvie
Every so often
RedSox Nation
I mounted a JL audio IB4 free air subwoofer in place of the Stock Subwoofer and i absolutely love it...i have another brand new one, if you want it drop me a PM
FordLover
Houston, Tx
Her94SHO:
I got a replacement from the dealership for 60 bucks. Best thing about it is it bolted right into place and the wires connected easily.
The car was totalled by a drunk driver so I have the speaker if you're interested in it.
BTW, it's a long throw 6inch woofer made by JBL.
-Martin
Kevin Airth
Home
I finally found that a JL Audio W06 is a perfect drop in replacement. Mounting holes line up and the depth is perfect. Much improved sound. I got 2 of them for $70 for the pair on Ebay. They are a bit rare to find but not expensive. Look on JL Audio website for more info.
http://www.jlaudio.com/subwoofers/6w0.html
