Can plugged cats cause the car to exhibit that annoying slight hesitation/stuttering throughout the band? I know it is the original exhaust. I just did the plugs & wires, the car will be getting new Taylors this weekend to check the wires, and the plugs are the Motorcraft replacements. Noticeable after the change up. All top end gaskets are new as well.
Can a vac leak on that hose that goes to the top of the intake by the throttle body cause this problem? What does that hose control, anyway? It's had a piece cut out of it, and is dry-rotted a bit, too.
Thanks!
Thanks!
