So I've now had this happen twice, and it is the same exact problem each time. It is really scary too, as it always happens on the highway.
When I put my foot into it, on rare occasions the car will all of a sudden stumble, throw a CEL for less than a second, and then within minutes it will start acting up. And by acting up mean I can't keep going 60, then I can't sustain 50, 40 30 20 or even 10. If I let it sit for an indeterminate period eventually it will run again, but I've now hit this problem twice.
The CELs are:
(KOEO Hard Codes)
21 - Cooling Temperature Sensor out of Range
24 - Intake Air Charge sensor or Vane Air Temperature sensor out of range
(KOEO Continous Memory codes)
49 - SPOUT signal problem
56 - Mass or Vane Air Flow sensor above maximum transmission sensor failure
55 - VAF-Mass air flow sensor fault, below minimum voltage
This is way over my head, could all of these sensors be bad?
The CELs are:
(KOEO Hard Codes)
