Stumble at 2.5k rpm
llamaking122
Green Machine
Columbus, Ohio
Even though i am leaking oil like BP i am still getting a stumble. I replaced the FPR and it still happens. its pretty solid from idle to 2k then it stumbles then it goes ok again. And it kinda hiccups
If this helps when i replaced the FPR they couldnt find the washer i had. it had like a rubber insert in the middle so i just used a crush washer.
firebat45
Edmonton
Try swapping out your ECU if you can. I had a stumbling issue , tried replacing MAF, coils, DIS, spark plugs, but it ended up being the ECU. Mine was bad from idle to 2500, but after 2500 it was like someone flipped a switch and the engine ran great.
llamaking122
Green Machine
Columbus, Ohio
Mine also Idles wierd. You start it and its fine idles 600 or so and you hit the gas and it goes to 1700 then you put it in gear and its fine again.
llamaking122
Green Machine
Columbus, Ohio
ok so i think i found the issue. i took the intake back off today and was going over ALL the vacuum lines and there was a big hole in mine. so ill let you know if that fixed it.
