strut rod parts
sho'd
Git R' Done
ontario,canada
ok here is my problem i have to order these part before 5:30 to get them for the morning, i have the front strut rod bushings already, i need the ones that go on the back of the strut rod, i think they go into the control arm, i need to know what they are called and what size, 21mm or 24 i thing were the options, i have a atx, anyhelp would be great. thanks
Minnesho
i was wrong
MinneSHOta
Do you mean the bushings that go on the rear of the strut rod on the FRONT suspension? or are you looking for the REAR suspension parts? they are just called the strut rod bushings. usually it comes in a kit for the entire front suspension or the entire rear.
sho'd
Git R' Done
ontario,canada
i got the ones that go to the sub frame, but not the bushings that go to werever they go to on the other end of the strud rod going. the ones that are in the front of the car.
sho'd
Git R' Done
ontario,canada
i got the ones that go to the sub frame, but not the bushings that go to werever they go to on the other end of the strud rod going. the ones that are in the front of the car not the rear wheels
Minnesho
i was wrong
MinneSHOta
The other end goes into the lower control arm, unless your buying high performance ones like TPR or energy suspension you'll probably only get them if you buy a complete lower control arm since its part of it. last time i checked they were $100 a side from bumper to bumper. some online vendors sell them much cheaper. just go with tpr bushings they will last you much longer.
projectSHO89
SHOless In St L
It's past the cutoff. but what the ****.
Moog makes 'em. I just purchased and nstalled a set about 6 weeks ago.
I just looked them up on the MOOG website and ordered from RockAuto.
Steve
sho'd
Git R' Done
ontario,canada
thanks for the info, i just order moog ones as well, they guy is confused at the parts store, he thought i meant sway bar bushings, thus the different sizes, o'well i'm off to get my strut rod welded, clunking like a mad man.
projectSHO89
SHOless In St L
Moog K8613 is the TPR version (1 set services both sides), K8452 is the rubber one (one set services one side - order two sets for complete car).
I paid less than $6 for the K8613.
You can also get these at many better auto parts stores (ie, not AutoZone). They will probably have to order them for you.
Steve
