slapnpop
Ok, so if matters weren't bad enough (see messed up 60k post), I somehow stripped two of the valve cover bolts on the front bank. they are the top and bottom bolts between #4 and #5 cylinders. I can't really afford a new head, so what are my best options?
Tap the holes a little larger and the bolts a little smaller and sleeve the two? tap the holes larger and replace the bolts with something else altogether? as long as all 8 other bolts are good, and these two go in, but don't tighten much, would it be ok to run like that? (I'm very hesatant to do that)
