Hello SHO Guru's. I just started having trouble starting my 94 SHO ATX. A few weeks ago, when it started getting cold up here in PA (single digit temps), the car would take two attempts to start...then run fine. Once warmed up, it would start on the first click of the starter. Last week, it would take dozens of trys before it would finally start.
New parts - fuel pump, strainer and filter...IAB...Cam Position Sensor...K&N Air Filter...spark plugs and wires...new starter and battery...ignition switch and steering column key lock cylinder...
No codes have shown up, either. It just now takes roughly 12 to 20 trys before it finally starts running...it cranks over fine, fuel pressure is up, the fuel pump is running, but, no ignition (ie. starting) - once it finally starts, then it runs fantastic.
Any clues on what the heck I can check to correct this problem? I'll probably fry my nice new starter if I keep this up.
Thanks,
Frank
Thanks,
Frank
