Stranded..crank/no start got the codes
beaudeen
BEAUDEEN
Shannonville, Ontario
Well...what I thought was a fuel pump problem turns into ignition NO GO...ran fine with no issues for 1 hour of the trip..stopped for gas..cranks, but no start..rpm gauge bumps up to around 500 while cranking..Had a code sheet in my glove box...ran codes..
126..cid
211..PIP circuit fault
219.. Spout signal default
542..fuel pump circuit
Had a spare DIS module in the trunk..swapped it out..no start
Have what seems like good pressure at the rail..good shot when depressed
wired a ground directly from l/h lower DIS mount screw to neg battery post..still no start.
pulled out the fuel pump crash shut off sw..cleaned plug and reset...no go
I have a spare cam sensor and 2 coil packs and another DIS mod back at home that I can get here in the AM..or is it the Crank sensor..?
Funny thing is, that I'm at Canadian Tire..no parts in stock..quoted me 3 hours @ $79 labor and $83 for the sensor..not horrible, but ...these guys are ok for tires, but..i wouldn't let them work on my lawnmower...might have to suck it up and cross my fingers...Thoughts would be GREATLY appreciated...!!!!
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
fuel pump keep priming? I was thinking maybe a ccrm.. but if the fuel pump was still priming i dunno...
You make it sound like it wasn't by checking the impact switch and checkin the fuel rail.. ;)
beaudeen
BEAUDEEN
Eric to the rescue again....
well...was sitting there for almost 3 hours screwing with everything...just thought i'd take the fuel cut off impact switch out for giggles...i'm really not sure it isn't a fuel problem..that pump is awful quiet, but there is pressure at the rail...??? No fuel smell under the hood..??
tompumped
VT
I had a code 219 in my first sho. It turned out to be the ignition module. I tested the wires and did every test I could perform before I replaced it though. It fixed my problem. Put the other module in.
I doubt you'd have one, but make sure the module isn't from a CA emissions car. I have one (I think) and the car will run for a few seconds and stall.
If there was a pip circuit fault I thought the tach wouldn't read properly?
beaudeen
BEAUDEEN
By ignition module, do i presume.the DIS mounted to the intake..??
On a side note, when I ran a ground wire from the lower dis mount screw, my alram horn started sounding off...that thing hasn't worked in almost a year...???
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
lol I think that ignition circuit is all tied in with the cid and cps IIRC... but I think thats fed from that CCRM isn't it? With the hood up and your head out the window.. I beleive you should be able to hear it click when you turn the key forward to run.
beaudeen
BEAUDEEN
CCRM..IRCM..i'm going dizzy reading..is this the relay that sparks up the fuel pump?? where is it located..??
if i pulled a plug and it was dry/wet, i guess that would rule out a few things
beaudeen
BEAUDEEN
I'm at an internet cafe right now..never thought i'd ever speak those words..LOL..there's a ***** bar across the road..going for a beer..!! will check back in an hour...thanks for the help.!!!
beaudeen
BEAUDEEN
OH...one last thought...there is a 95 atx at home in the bone yard intact...is that relay common to both atx/mtx..if so, i"ll give my brother a call to go and pull it..a realtor getting their hands dirty..would love to see that..
tompumped
VT
That's strange that when you ran the grounding screw that happened. You might have a short somewhere.
I was talking about the dis, I thought you said you had a spare.
Have fun, I haven't been to a ***** bar in years.
beaudeen
BEAUDEEN
Back...nothing worth watching there..2 BIG girls on stage..better beef up the floor joists...lol
Well..i really can't say i hear the ccrm clicking..can't be sure though...i hear the fuel pump kinda prime when the key is turned to on...when i pulled the codes, the first time, the check engine light was really dim, but the codes flashed bright,,I did swap another DIS in..had a spare in the trunk..the car did run with that one when i pulled it off because the connector case was cracked
beaudeen
BEAUDEEN
Done for today..in the AM, i'll pull a plug and check for spark..check the iirc..make sure it's clicking..give it a good whack..check the 10a mini fuse in the engine fuse box accy feed..power to the inertia trunk sw..connectors under the drivers door trim...other than that..????
SuperHO
Mental Patient
St. Joe, MI
why not just pull a plug wire and jam a screwdriver into it to check for spark? surely you know that method. also, if the CID is broke, it'll still give it spark, just at the wrong time. i'd start there.
beaudeen
BEAUDEEN
Never thought of that..chasing my tail around most of the day...I just remembered I have a spare plug or two in my trunk..feel like a ******** now..lol
shocar
shocrazy
Bend
I just had this happen, check the ground wire that is attached to the front right strut tower frame, check the crimp that connect the wires wires. It is not one of the green grounding spots. Mine were corroded and that is all it took. Undo the crimp, clean the wires , recrimp and that should fix it if that is the issue, So simple it made sick. If you hear a buzzing sound when you have the key on, then this may be it. Try having some start the car while you wiggle the wire around, if it starts and then dies because of you moving the wires around, you have found it.
SuperHO
Mental Patient
St. Joe, MI
by the by, code 542 means the car stalled at some time or another since the last time the codes were cleared.
beaudeen
BEAUDEEN
Cleared the codes the night before..had the battery out all night..started up normally in the morning..drove for and hour and stopped for gas...the engine NEVER stalled out since codes where cleared...and now a 542 code..???..along with the others
heading back to the car in about an hour...fingers crossed..hope i can figure this out
