stock sub
HELLBENT93
Phoenix, Az USA
anyone know where to find a replacement 6.5 inch sub for the stock sys. on a 93? does anyone even make anything that will fit?
mrjfranklin
Indianapolis, Indiana
Radio Shack sells a replacement 6.5 sub that fits perfectly in the sub box for about 15 bucks. It sounds pretty good, but get this. While I brought the Radio Shack sub and installed it. I had my factory sub repaired at a local speaker repair shop. The comon problem with the factory sub is the lead wire breaks or become loose. I had the lead wire replaced for 10 bucks and swap it with the Radio Shack sub. Both subs sound about the same.
BBsPG4
Kansas CIty
My sub recently started sounding like crap, I believe it is blown so does that lead wire thing have anything to do with that? Radio shack has a sub that fits, will it work with the factory amp? How do you install it? Do you just have to swap it and it uses the same wires etc?
Brian
SHO_POWER
Ontario, Canada
I think that Kicker makes a sub that will fit in the stock enclosure, with some minor modifications. Anything would sound better than something you buy at Radio CRAP.
Greg
naval-avi8or
Chesapeake, VA
Indeed Stillwater/kicker males a sub that will fit. You can also take a 8" kicker and with a small modification fit it in the stock enclosure and get more proformance.
