stock sub rms?
Fudog
Sac town CA
I think my sub amp is burned out. what is the max and rms of the stock sub?
I have a kenwood 125w 2 ch amp and a road gear 80w 2 ch. can i replace the stock amp with either of these?
shoteen95
isn't a teen :D
Dearborn Heights, MI
i dont know for sure, i think it's like, 65 or 75 watts...
are you sure it's the amp, and not the speaker thats blown? I actually have a stock amp and sub lying in my closet back home..both of which were in perfect working order when removed..(altho, you will have to re-connect the speaker wire to the terminals on the speaker itself).
leave me a PM or hit me up on aim if you want em, i'd probably let em go if you just payed for shipping.
Also, with an aftermarket amp, you'll have to run a power wire from your battery..and hassle with either speaker level line inputs (which hopefully one of those amps would have), or run RCA's up to your headunit (if you have an aftermarket headunit with a subwoofer pre-out). And even then, you could still blow your sub..or it could already be blown..
OOOOOR, you could just do what i did and forget the stock amp and sub, wire up your own sub, and stuff an 8in woofer into the stock box (after a little..modification, ofcourse) *wink-wink* http://www.shoforum.com/showthread.php?t=39636
Fudog
Sac town CA
That sounds like a great plan Steve. Are you going to lend me the money to do so??? :biggrin: :naughty:
shoteen95
isn't a teen :D
Fudog said:
That sounds like a great plan man. Are you going to lend my the money to do so??? :biggrin: :naughty:
i'm going back home for the summer late late tomorrow, sometime this weekend i'll get back to you on the shipping cost of that amp and sub if you're still interested :)
Fudog
Sac town CA
For sure man. Thats just what i was lookin for. By chance you know anyone with a cheap/used/working slave cd player or cd head unit (stock or after market)? If so I might get those from u too. :biggrin: :naughty:
Thx again man
I really appreciate it.
Fudog
Sac town CA
thx bmcreider
Ill try the road gear first to see if its the sub or the amp.
