stock sub enclosure
MassSHO25
Webster, MA , USA
hey will any other subs fit into the stock enclosure? I have the JBL soundsystem and was looking for a little more punch but not too much (neighbors are ********). I heard its a 6.5 driver?, I thought it was an 8? well anyways if anything decent will fit in there thats in improvement over the stock sub let me know! also is there anyway to turn up the amp? i don't really know much about amps I just know how to install speakers heh. I looked at the amps and didn't see any switches or anything like the ones i'm used to.
SHO_POWER
Ontario, Canada
yeah I belvie that Kicker makes and 8 that fits into the box. I am almost positive that there is no way to turn up the factory amps.
SHOtime93
Michigan
Well, there are component speakers that you could use instead of the stock sub, but it wouldn't sound much better because the JBL amp in our cars is not exactly high powered. If you don't want an aftermarket sub/amp setup, just get a couple good 6x8's or somethin and put them in place of the stock ones and you may notice a difference, especially if you have an aftermarket CD deck that pushes out good power. I'm not sure about turning the amp up or down, my guess is that they don't have dials like a regular amp and can't really be changed, but I'm not sure.
1993 White SHO ATX
Stock under the hood so far...
GTS Headlight covers
Saddleman Hood Bra
GTS Sunroof ventvisor
Tinted Windows
"SHO" windshield decal
"SHO" filler decals
400watt PPI amp and a single Fosgate HX2 12"
Powered by YAMAHA
MassSHO25
Webster, MA , USA
yeah thats what I figured about the amps. I'll probably just add a new amp and 8 for the enclosure and new 6x8s. who knows i'll probably end up replacing everything lol. I have a pioneer premier cd deck so i think it can push decent power (it did in my other car) which was loaded with Pioneer Premier everything. the only thing that sucked about getting rid of that car was that i lost the system that was in it, it was deep and powerful even without a sub. and since none of the measurments are the same as the SHOs I can't use them.
Aspect
Lowell, Michigan
Just replacing the speakers will not necessarly give you better sound. Replacing the speakers with quality (JBL, Infinity, Polk, Alpine, etc..) will help but replacing the amps with them will do the trick. Factories like to use 8-10 ohm systems while the aftermarket uses 4 ohm systems. Don't mix'em. Stay factory or switch entirely. That is only way to achive the best quality.
93ATX SHO OFF
Basehor, Kansas, US
I put a 8" kicker solo-baric into mine, but i had to cut out the indented ring that the stock speaker sat in, for the speaker to fit properly.
AIM:FrdTaurusSHO
1993 ATX
K&N Cone
20% Tint
Lisesnce plates: SHO OFF
Pioneer 8000R CD Player
Police Interceptor Badges
Amber "Fishtank" Lights
GTS Blackouts
Colgan Custom Mini-Bra from CincySHO
IPT A-Pillar Gauge Pod with Autometer Gauges
White Filled Body Letering(Thanks to: Stallion's90SHO)
TransGO shift kit
8" Solo-Baric in stock enclosure
MassSHO25
Webster, MA , USA
thanks alot you guys, I bought a kicker, and put it in, replaced the amp too. Sounds about where I want it :), i think i just need to get new fronts and I'll be set!
SHOnOFF
Voorhees, NJ
Can you tell me a little more about how you did this? What model and size? How many ohms? how much did it all cost, too? and how does it sound? solid? Thanks man.
Brian
'94 Green ATX
5%/13% Tint
Coneless/Boxless
Valve Lash Adjustment - Finally! (8/18)
Blazer driving lights
96 Brake Upgrade
24/26mm sway bars waiting to go in (need bushings)
T
ThatSHOkid
Guest
what r using for amps? i just read in another post canlt remeber who and what topic that a kid with a sho had a car stereo shop splice the wires going into his amp or do somethign along those lines to beef up the existing power by his stock amps. it escapes me at the moment (damn!) anyways, how much did u pay for a kicker solobaric?
1993 White/Tan SHO MTX 96k Miles
[*] Eagle Super White Headlights ** American Products Company Super White Reverse Lights ** Hibrid Double Watt Super White License Plate Lights ** Colgan Custom Bra From Cincy SHO ** Gen. 2 Font "SHO" Windshield Banner ** Superchip Performance Chip ** Blacked Out "SHO" Lettering ** Sho Shop Y Pipe ** Coneless & Boxless ** K&N Filtercharger ** Blazertech Super Clear 55w Foglights ** Ventshade Sunroof Wind Deflector & Vent Guards ** GTS Headlight Blackouts ** Sony 10 Disc Changer ** All Possible Options
[*] Coming Soon: Tinted Windows, Nook Sub Frame Connectors & Sway Bars, Front Strut Tower Braces, & A Sig Pic!
[*] The Driver: Jay/Jason/Hubes
[*] The Car: Zsa Zsa
[*] The AIM Screename: KingPin641 (I am a NESHOC member)
***"Drive it like you stole it!"***
