Stock Size Swaybar for rear of 92?
SHOMA
Springfield, MA
Title says it all.. My car isnt here, and I was trying to figure out what size my car has on it from the factory, for a RSB.. Thanks for any and all info!
Kevin
SHOMA
Springfield, MA
Thank you for the info! Now, with koni adjustables/eibach springs all around, will the 26mm be a good upgrade for the rear? Thanks in advance for the info.
Kevin
Sho-Driver
Peter Pan
The Garage.
I've got Eibach/new stock struts with a 24/26mm (TPR bushings and endlinks in the rear and stock worn rubber in front) combo on my '92 and can bring the rear end around on command. At speed on track, I can easily induce lift-throttle oversteer. I will actually be stepping my front bar down to 22mm with grease-able poly bushings.
With the stock 24/23 combo, I had dangerous understeer. I would definitely recommend a 26mm sway bar for the rear.
In my other SHO, I am using Koni/Eibach with the 22/26 and I love it. This car also has a Quaife.
313tiger
