Stock fog light harness
marlonius
Holden, MA
Can anyone tell me where I can find the little harness that the fog light bulb plugs into for a Gen II? Or at least a part number? All I need is the piece that's about 6" of wire with one connector that goes on the bulb and the other connector that goes to the rest of the fog light wiring system. One of the contacts melted the surrounding plastic right to the bulb's contacts. Or if anyone has one lying around that they're not using, let me know. I would like to avoid wiring a new system.
Bizzy
I think you need to first find out why the connector was melted before you replace it. Any ideas as to why it melted? Too hot a bulb? Short somewhere?
marlonius
Holden, MA
Bizzy:
I believe moisture might have been the culprit. The gasket looked a little worn and when I pulled the bulb, a trickle of water came out from inside the connector.
Ishodu
You mean the plug for the bulb and the 6" of wire after that? I have one here its not actually one off an sho. Its for different fog lamps I installed. But I didn't have to Install them cause the factory onec fit it. So I would imagine these would work for ya. Email me if your intrested. ([email protected]) There only taking up space here.
Bizzy
I rewired my system, if the harness is the same I'll pull mine and you're welcome to it. They're just hanging around anyway.
marlonius
Holden, MA
ishodu:
I received the plugs. Thanks. I have working fog lamps again. I appreciate the help.
