ManySHOs
Time to clean out the garage!
SHOshop 80mm MAF with filter and elbow - $95 or best offer. Requires a chip or TwEECer to run properly. I do have an LPM for it which is in unknown working condition but programmed for an X2J PCM. It needs a new ribbon cable connector.
69mm throttle bodies- I have 1 left! $ 85 each or best offer. The throttle body plates are loosely assembled to the shafts. I would recommend using a threadlocker of your choice and milling off the ends of the screws before installation on your car. I never installed these after they were bored out. (1 left)
80mm MAF's. I have 1 left. $45 each or best offer.
SHOshop carbon fiber front strut tower brace - $125 or best offer. (new lower price!)
SHOshop carbon fiber rear strut tower brace - $125 or best offer. (new lower price!)
Picture of the CF since the pictures above don't do them justice:
Tim Dahm aluminum front strut tower brace. The bar's diameter is actually larger than the one it came with. The mounting ends have some paint overspray on them that should clean up easily. They also have some gouge marks on them but if you are ambitious and spent time cleaning them up, the entire thing could be polished for a really nice look. These were rare even when available. Very lightweight and strong. $100 - SOLD
4 koni struts (inserts only) with 10K miles on them. Includes new hardware from Koni. $360 shipped for all four. I never installed these on my car - I bought them for a coilover project that I did not complete. I cannot compress them between my hands (granted I'm tired and I haven't worked out lately) but my impression is that they are nice and strong. The rear inserts are the long version (89-mid 93ish). These are boxed up and ready to go! SOLD
Strut housings without spring collars (I removed them to install coilovers) are also available as well as the last IPT coilover kit ever made for the SHO.
Magnaflow Y pipe for an MTX SHO. Has an additional O2 bung for a wideband O2 sensor. This can be plugged with an O2 sensor delete thingie - it looks like a bolt and is a few dollars from most parts stores or exhaust shops. This Y pipe was from the first batch ever made. There was a slight fitment issue at the catback which was resolved by heating the pipe and slowly bending it to mate to the catback. I had an custom exhaust at the time but that was once mated to a stock Y pipe. With that in mind, I would speculate that this pipe will fit a stock catback or aftermarket system without a major problem. The work that was done to heat the pipe and bend it is invisible to me. If you're interested in this pipe but nervous that there might be an issue with installation, I would recommend having an exhaust shop install it. A competent shop can devise quick solutions to get it to work IF there is a problem. $225 or best offer. SOLD
89-95 mtx reconditioned 3.0 oil pump (can be used for 3.2 mtx conversions as well). These were disassembled, glass beaded, hot tanked and reassembled with assembly **** by a local engine machine shop. As with all parts listed, no guarantees, warranties, etc on parts. I only make mention of this as this is an internal engine part and I can't take responsibility for damages incurred stemming from installation of this part. That said, I have been running one of these reconditioned pumps in my 3.2 for years without a single problem. My machinist is extremely competent and I don't foresee any problems with these.
With new Ford front main seal installed (1 available) - $130 or best offer
Without front main seal (2 available) $120 or best offer
used SHONUT bolt on fuel pressure regulator for larger than stock fuel pumps. Sells for $230 new, asking $160 SOLD
Used TCE rear knuckle braces. I had to clearance these slightly to fit my car. Your fitment may vary. $75 new, asking $45 or best offer SOLD
89-95 mtx engine roll dampener brackets powdercoated black. I never installed these after coating. $60 or best offer
NEW SHONUT sourced NSK idler pulley bearings for MTX idler pulleys. $30 each SOLD
Jose/rktm's transmission boss brace. Was installed on Mark Nunnally's car which adds $1000 in value but I'm only asking $95 or best offer.
More parts and pictures to follow. Please PM me if interested. All parts are used unless specified. Sold as-is, no warranties, guarantees, no returns (I'm just covering my bases). Prices do not include shipping. Shipping is from 08098. I am willing to discuss lower offers but only after this ad has been up for at least a day or two. I do accept paypal but I would prefer a bank transfer to avoid the 3% fee. Credit/debit cards are fine too but please consider covering the 3% fee for anything over $50 if you must use a credit or debit card.
Thanks!
Ian
Thanks!
Ian
