adidas_kn
LOWSHO
Okay soo I think the combo of a weak Optima Blue top relocated to the trunk plus a full set of UDP's on my 93' might be causing undercharging. I dropped it off at the body shop last week and when I came to check on it the battery was dead as a door nail. It sometimes illuminates the Battery light at idle but goes away after a quick rev. It seemed to run really well before I dropped it off. Maybe the Battery is just completely dead now. I'll throw in on a charger for awhile and then see how well it checks out. Could the extended run of power wire and the use of UDP's cause the battery to not fully charge? I did run extra ground wires in the back and in the engine bay just incase. Now if this is a problem can I reinstall the stock alternator pulley with no ill effects? I will be shipping the car in the next month and don't want to worry about a new battery dying and them messing with it since it's in the trunk. Will the under drive crank pulley and the stock alternator pulley cause the new alternator to over spin or blow up if I rev it too high?
I will put a new Redtop Optima in the trunk and see how it goes but I want to know if the pulley combo will be okay for awhile.
