Still no start, but found something interesting...
93redATX
SHOForum O.G.
WI
OK, finally I've got fuel to the engine. Still no spark, but the strange thing is the coil pack wiring. After testing with a multimeter, I found that only two of the four wires had any voltage at all when the car was "ON". The first two had no juice at all, the third had right around 7, and the last one had high 12's. When my dad was trying to get the coil pack cover off, he accidentally hit the wiring clip and broke the prong, but could he have damaged the plug? It seems likely, but I don't know what he could have done. Also, there was no spark at the coil pack itself. TIA
-Andy
'93 Red/Black ATX
"Nemesis"
"The Daily Driver"
-Coneless
-Red interior lights
-Fog light mod
-Pioneer DEH-1100 45x4 MOSFET Head Unit
-SHO lettering painted black
-SHO banner on windshield, SHOforum.com sticker on back window, bottom center
-Gen IV Taurus emblem on trunk
Just Added:
'89 Light Titanium/Grey MTX
"Aphrodite"
"The Project Car"
-K&N Panel Filter
-Poor Man's Ram Air
-Boxless
My Website: http://taurusshosite.8m.com/main.html
AIM:Juggalo53048
AutoXSHO
Glenwood, MD USA
Without having my service CD here, I don't know what the voltages are supposed to be at the coil pack. You'll have to have someone check their Helm or CD to verify those voltages.
Can you run the KOEO codes? That would tell your for sure if something is up with the coil pack wiring...
JV
93redATX
SHOForum O.G.
WI
OK, it's now up and running, seemingly as good as it was before (minus oil in the plug wells). The problem was with the DIS module ground. Anyway, I've now only got one problem-the t-stat housing tube (the piece that connects the Upper Radiator Hose to the engine) is leaking. There is no gasket there, and it never leaked before, at least not that I noticed. RTV didn't work, so is the t-stat gasket bad? Since I didn't put the t-stat in, I wouldn't know if there was a gasket there, or if it was done incorrectly, etc.
95SHOATX
Rochester, NY
As for your leak, you probably will have to replace the thermostat due to the fact that the rubber gasket is part of it. I doubt RTV will work. The thermostat is fairly inexpensive. Use caution when removing and re-tightning the nuts. You can easily strip the studs out of the block.
Shoman594
Moderator
Lockport, IL
ya there is a rubber gasket there it is not the normal gaskets of old times. take a look might as well be a good time to change the ts.
Ryan
SHOcago Enthusiasts Club President
SHOcago Web site
http://www.SHOcago.com
SHOcago SHOforum.com Board
http://www.SHOforum.com/SHOcago
'94 Opal Frost MTX "Shoman 4"
'91+ Deep Jewel Green Build Date 6/91 with rod shifter
AIM "Shoman594"
To Join SHOCAGO Enthusiast Club, Please Email me
E-Mail mailto:[email protected][email protected]</A>
7020941 4985 020000C3
The seal at that interface is the rubber surround on the perimeter of the thermostat body and functions more like an O-ring than a gasket. There is no gasket between the metal surfaces of the block and the tube. Some replacement thermostats come with the seal, but it is also a separate part number in the Motorcraft books.
Scott
[This message has been edited by sdpatt (edited 12-11-2001).]
