still no spark
MATT HOWARD
ST. LOUIS
i need some help, i have a 93 atx sho with 125,000 miles that died on me about a month while driving, i found that i have fuel pressure, and when i checked for spark i found i did not have a spark, so i installed new plugs and wires, new coil pack, new cps (properly gapped), timing belt and water pump(old pump was leaking), and also changed the dis module, after all this i still have no spark, so i checked for faulty wires and connections and could not find a problem, i think im out of options, any help would be great.
twr
whoohoo
half-way there, I think.
The only other thing that comes to mind is the CCRM module. It sits just above the radiator on the driverside. They have been known to cause similar problems. If you can swap it out for a like module (must have the same Letter code on it) from another SHO, that's the easiest way to diagnose it, unless you have a wiring diagram and feel comfortable trying to bypass it.
