rocket455
So one day, I noticed that my brakes were only working on the front. I check my fluid level and the reservoir was empty. Upon further inspection, I find out that the master cylinder is bad. The rear seal on it was leaking and all of the fluid was in the Brake Booster. I replace the Master cylinder and remove the fluid from the booster. The Master cylinder is bench bled and installed. I bleed all of the brake lines.
After this is finished, I roll the car out of the drive way and the pedal is stiff. Like it wont hardly budge and the car is barely slowing down. So I figure, its a bad Brake Booster. I replace that. Reinstall everything, re-bleed everything. Same outcome. I am in a bind and can not figure this thing out. The new brake booster is holding vacuum as it should.
Help me, SHOForum
Help me, SHOForum
