stereo install, speaker problem
fast4door
wichita
Started to replace the stock cd player and tape deck and it looks like someone at one time has spliced the 2 connectors together, I do not have the black connector for the speakers but have the gray connector for power to the headunit and it looks like they spliced everyrthing into that connector. What are the color codes so i can hook speaker wires from the headunit into the car speakers?
Joe
fast4door
wichita
ok ended up figuring out what they had done. Problem i still have is poor sound from the drivers side speakers, I thought it was the speaker amp and that wasnt it so put an aftermarket headunit in it and unplugged the speaker amp and still have hardly any sound, is it possible for both the drivers side speakers to fail?
trainguy1989
SHOtarted
Wichita, Ks
doubt it.
Radio Constant 12V+ Wire: Green/Yellow
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: Orange/Blue
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2″
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5″ x 7″
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Pink/Light Green
Left Rear Speaker Wire (-): Dark Blue/Orange
Right Rear Speaker Wire (+): Pink/Light Blue
Right Rear Speaker Wire (-): Tan/White
fast4door
wichita
I lost sound in the drivers side befoe the headunit swap. I replaced the speaker amp thinking it may have burnt a channel out and that wasnt the issue and even with the stock amp by passed and a new headunit I still have the same issue.
trainguy1989
SHOtarted
Wichita, Ks
Bad wiring? Take a drivers side speaker out and hook it directly to a receiver and see how it sounds. Thats just a weird issue.
fast4door
wichita
I will give that a try tomorrow. May try swapping the driver and passanger speakers ad see if it does the same thing
