Steering Wheel Swap (Focus)
SHOkid13
Take it to the track
Temecula, CA
Has anyone done it? I like the Focus wheel, it is smaller and has a larger diameter "ring". It's much more comfortable for my big hands.
Is it possible, er cost/time effective, to use the SRS after the swap? Can I still use the cruize control?
Thanks!!
nc89sho
S13 Sellout
Clemmons NC
noone has done it, but it's probably possible. i would think that wiring would be a poss. problem. don't know if the mounting is the same or not.. only way to find out is to get one and tear into it.
SHO92
Upper Freehold, NJ
The Focus probably has the Gen 2 Airbag system, which won't work on a SHO. The way to tell if the ring will fit is to find out if it has the same hub as a Mustang. If it does, then it will fit.
SHOkid13
Temecula, CA
I was curious about the Gen 2 airbag situation, but I am not a huge airbag fan anyway. I just want the wheel.
I am searching around for one, so I'll post back when I figure it out.
