Steering Tight then Loose...
Jason Bowles
Curious Kid
Lacey, WA
The steering on this 1993 ATX SHO as you hold in a turn get loose then tight loose then tight etc. Anyone know the deal on this?
<small>[ February 07, 2004, 09:31 PM: Message edited by: Bizzy ]</small>
SonicRiot
Handbanana!
CT
are you mashing the accelerator and the steering is getting tight?
TYSHO
Earth
You 'need' to change your VSS. You mentioned you have simular tranny problems as another on this forum and now the loose steering. Your VSS is bad and can't detect your vehicle speed to tighten up the steering.
Good luck!
Edit: About your changing the atx to an mtx...it would be cheaper to buy an mtx with all the hassle you have to go through and parts.
<small>[ February 07, 2004, 09:18 PM: Message edited by: TYSHO ]</small>
