The problem is that the GM bars only cover 2 holes,right next to each other,it doesn`t pick up enough of the studs.For example,the SHO studs are in a triangle pattern,the GM bars have two oblonged holes,one on top of another.Basically,the long holes look like this "=".You either drill one single hole in the middle,or extend one existing hole,and bolt it on offsetting it.To acually use a decent bar made for the GM pattern,all 3 holes will not be able to bolt to the studs,only one(possibly none depending on the mounting procedure).Working in a machine shop,you could possibly use just the bar itself and CNC a new set of plates,but at that point,it`s more cost effective to just get an SHO correct brace.Basically,the GM brace is a band aid even on a GM,to use the better bar for our cars,it won`t even fit if you did redrill the holes.
<small>[ March 07, 2003, 10:44 PM: Message edited by: jthomas68 ]</small>
