Starts drives, then dies on next start after sitting
goalieman59
Learning Slowly
OFallon, IL
So I started my car yesterday drove it for about 45 min, made a stop for about 5 min car started right back up. Then we drove for about 15 min more stopped for about 30 to 45 min, then when I tried to start her back up she was chugging on start up. After getting her to start I have to hold the gas for a min to keep the rev up then once I get her going she runs fine. Any idea what this could be? I did a front 60k over the summer, and then I just replaced the CID. I have not gotten a chance to pull codes yet I will be doing that tomorrow. The fuel pump is like 1.5 years old, along with the fuel pressure regulator. Thanks
sperold
Last to Know
Any leaks from the water pump? Have a close look, any leak ends up on the crank position sensor.
goalieman59
Learning Slowly
OFallon, IL
So i dont see any leaking, why would the car start when I give the car gas if it was the crank sensor. I also have a hard starting issues could this be related. This was present before I replaced the crank sensor, and continued after the repair.
SHOMac23
CA
I've been having the same problem with my 1995 SHO. Just replaced o2 sensors, water pump. Every once in a while, it will chug after sitting, starting to be a concern.
eminem3150
FL
I just had this problem. Remove the cam sensor and check for oil in it. If there is, replace the seal and sensor.
goalieman59
Learning Slowly
OFallon, IL
mine does the same thing after sitting for about 45min or a little more.
shobroooo
