95SHOdude
After a bunch of fixes now I have an overly agressive starter. It's brand new (autozone rebuild #3) and I just put it in. After a short drive at a stop the car just started freaking out. The starter was trying to engage while the engine was running. I quickly shut it off. Then whenever I turned the key just to "On" it fired up and the starter didn't disengage. Iended up cutting the inginition wire to the starter and push started it. It ran just fine all the way home. My question is did I get a bad starter? Or did something else like a relay fail closed. My CCRM did burn the fuel pump trace and I was able to fix that. I was thinking of just putting a momentary push switch to the ignition wire I cut and start it that way. I'd hide it somewhere and make it really difficult for someone to start it. Is the ignition wire a ground or 12 pos? Thanks.
