Starter Troubles.
MarkieSHO
Manchester
Last week , i had my tranny taken out for a leak in the front, that was fixed, but now my starter is makign noises when it starts...Mainly clicking and grinding sounds, i went back to the place, they replaced the connectore to the starter , and i seemed to wrk fiin, for a day or so, now its doing it again....HELP!
93SHO'nOFF
And you are...Who???
Lehigh Valley,PA
Check your ground wire at the transmission,it gets secured to the top stud at the starter motor.Since the trans was just removed they may not have the nut that secures it tightend completely or the eyelit on the cable end could possibly be damaged.When using air tools to remove the ground wire it sometimes breaks the whole stud loose and twists the cable around the socket.Usually it damages the cable and/or connector.This could cause a no crank/click condition.
Later, :thumb:
