strings1732
RMTE-TRBO-SHO
I replaced the starter and solenoid about a week ago due to this same issue. for a while it works perfectly. Then I will go to start it and the motor will start, but the starter continues to try and start the car. I can remove the key from the ignition and the starter will continue to turn over. Even while driving it will be trying to start the car. the starter is frying(literally it's smoking) and so is the solenoid(again, literally). The car is my 91 and it still has the solenoid on the fender. any ideas? Anyone had this issue before?
Edit: forgot to add, that if I disconnect the wire from the solenoid, the probem stops. The wire I have been disconnecting is the large wire towards the front of the car. I'm pretty sure it's the one that goes to the starter(but I'm not positive). Which leads me to believe I need to replace that wire.
