stalls w/climate control on
nodram
sauk rapids, mn
My '92mtx runs and drives fine with the heater or fan off on the climate control. When its on, driving can be more of an adventure. It will stall in neutral most of the time. Like coming to a stop in neutral after taking it out of gear. The rpm's bounce up and down a couple of times then it stalls. I had changed the MAF plug and the speedo sensor. This did not seem to help. I read through some previous posts, but none dealt specifically with this situation.
Ishodu
What your seeing it the extra drag caused my the AC. You can try switching to vent mode to see if this stops it. And try reseting your idle, theres a how to in the "how do I" section on this forum.
