Stalling
Wht91+
93 Green MTX
Oconomowoc,WI
Saleen SHO said:
Sorry to bring it up... i was just curious, thats all..
:thumb:
Back on track:
How the **** did you remove the CPS without removing the dampner??!?!?!?
i took the crank pulley off but not the lower pulley for the timming belt. there is a slot that you can put in through. then i dropped one of the "phillips screws" why its phillips is beond me.
David's Plus
Medford, NJ
Back on track:
that is what i can't get off sorry
alright i had my air compressor to the max at 125 psi and i didn't break, I tryed to pull with my body weight and that didn't work, I guess the only thing to do is to put it back together and take it to a shop that can get the pully off. this sucks
unless you can help
SASHO91
Zoom Zoom
San Antonio,TX
Oh, ok.. i thought you meant the dampner...
Yeah i dont pull the Tbelt pulley off either. (only when changing a tbelt...)
David's Plus
Medford, NJ
yeah i have never heard of the method and was wondering about it. I am going to try it because nothing else is working, thanks for the link
SASHO91
Zoom Zoom
San Antonio,TX
the one from auto zone... its a kit... hold on a sec.
EDIT: ok nevermind.. Autozone's site isnt working too great...
either way, they have a kit there that has what you need.
Wht91+
93 Green MTX
Oconomowoc,WI
I used a 2-jaw pulley puller :thumb:
spray it with PB Blaster and it will come off:salute:
Ishodu
Its quite easy to damage the lip of the pulley using that type of puller.
Wht91+
93 Green MTX
Oconomowoc,WI
um ok but i had the impact whaling on it and when it finally came off there wasent any bends, cracks of anything. it was fine. for some reason mine was a pain to get off. i've done others and they came off with ease. i also did them the same way.
David's Plus
Medford, NJ
thank you for all your help i finished up the car this morning and it runs good but the tach is still not working right???
David's Plus
Medford, NJ
Got another problem, after i finished and put everything back i test drove it and the car seemed to do good, but not unitl i drove it for about 3 miles did all this smoke start coming out from behind the dampener pully, the only thing i can think of is the timing belt is getting squizzed between the cover and the belt it's self??? Has this happened to anyone before?
