Need help once again. Just had the codes read at Autozone. Came up with a 212-IDM circuit failure and 215-Coil 1 primary circuit failure. Question, Is there any way to test the coil before replacing it. Will this stall the motor?Could I have bad plug wires? The car has been experiencing stalling problems for roughly 3 months. While attemting to fix the problem, the following has been done. New DIS(have the old one and swapped them when stalled and doesn't make a difference). CPS replaced along w/water pump and timing belt. Cam sensor replaced which seemed to solve the rough starting and no tach that developed. However, the next day my wife drove to work and back fine(45 mi one way), then she stopped at a friends a few blocks away from home and it stalled on the way home. Started up again, stalled, and then made it home. Seems to only stall either at low speeds or stop. Sometimes the engine is hot, other times it has stalled a few blocks from home. Could I have a computer problem? What component sends the codes? Every time I take it in to read the codes, its always something different.
