Stalling and won't start: part 2
DDakRT
Mississauga, Ont, Canada
Here's the update on my car. It fired back up last night, but today it died again while on a drive.
It will stall once it warm up a bit, but after it totally cools off it'll turn over on the first crank like usual.
I'm getting fuel pressure when it dies, but no spark.
Will the CPS cause the car to die when it warms up and fire back up when it's cool?
Someone suggest that it could also be the igition module?
Any ideas? :confused:
yamahaSHO
E85 whore
Arkansas
From your description, the CPS sound like a good possibliity. If that turns out to be it, check to see if your water pump is leaking from the bottom weep hole. I plug my bottom one so it has to come out of the upper one. That way, I see it easier.
DDakRT
Slo-Sho said:
Pull the codes, some ignition related DTC's will not illuminate the CE light.
No codes, a couple of stored ones from before but those are unrelated I think.
If the waterpump is leaking, does that mean I'll need a new one?
yamahaSHO
E85 whore
Arkansas
If the water pump is leaking, you'll need a new water pump. A leaking water pump can also cause CPS failure as it does not take well to coolant.
When is the last time its all been replaced?
tinkerkathleen
