sd , your right i didn,t put it in 4th or let gears stop turning before shifting!it dosnt stall regularly i was in a rush,not any more.i didnt get secondary fuel pump code,so let me tell you about today.first off i,ve already done cps up,i own an 89 parts car so i started changing ignition parts[89 ran fine until today].first dis mod.,nothing.then cam pos. sen. ,no luck,then coil pack...then eec guess what?NOTHIN' AND NOW THE PLUGS ARE SOAKED!!!!! so i must have fouled the plugs ,well [i know not to run anything but motorcraft rip off junk in it]but now i'm desperate and ******,and FORD is'nt open on sundays!so off to NAPA to find a compatable set of plugs.autolite makes one ,part#AP3924 yes it is a platinum plug and under $2.00 and it looks identical[except motorcraft markings]anyway I dried all cylenders put in new plugs and BANG!! still nothing...sooooo i shut down fuel pump and connected scanner again ,now i get FPM circuit [because i triped monitor]and thermactor air system problem - right side air flow always upstream, code 95.also thermactor air diverter[TAD OR AM-2]solinoid:circuit failure or electro drive fan:circuit failure, code 81.so where in the f..k is the thermactor and what the f..k does it do............!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!i hate to pay FORD but after 8 hours and the most typing i heve ever done,one more hour i give up.
