Stall less than 1 mile and no RPM's
JLaughto
93 ATX - Will start,but dies less than a mile down road.
The CPS has been replaced,
When running has great power, but the TACH stays at 0?
any ideas, it happened overnight?
Thanks,
JLaughto
Found error codes
Looks like I have a 212 and 214 error code stored in memory?
Mr Anonymous
Tire Wall
Check all you ground path connections from the DIS module, through the intake, and to the firewall and make sure they are all clean and tight. Usually both a 212 and 214 are indicative of a bad ground rather than an actual sensor failure.
