Sr 72 sold ... Selling all sho specific tools and parts
1badsho
Port Charlotte Fl
*********************UPDATED 10/13/2009********************************
Still have some good stuff to sell. Have a parts manual ... a STAGE I cam installation tape still available ..... a rotonda code reader .... the official SHO rotonda tool kit .. a must have .... a helicoil set for the cam threads ..... lots of goodies actually .....
Just click on the photo bucket and each picture should give u the price
http://s256.photobucket.com/albums/hh161/1badsho/SHO PARTS/
*********UPDATED 08/25/2009*****************************
Please refer to the photo bucket link to see what I have left.
Still got lots of great stuff but alot also has been sold.
Heres the link ... price does NOT include shipping.
You will find this same post at the end of this thread but I also decided to update the my intial thread as well .... sorta of make it easier for you to find what your looking for.
Heres a updated list of whats still for sale.
Lots of goodies still available .. just click on the photo bucket link to see your item and pricing. All parts shipped out immediatly. Buyer pays shipping.
My pay pal addy is:
[email protected]
Enjoy !
- ford rotunda code reader .... the REAL CODE reader that FORD shops use .. a easy to use tool that tells u exactly whats wrong with your SHO
- josh t differential preset tool to install new differetials/quaifes with the proper pre load
- ROTUNDA SHOP BOX FOR SHO'S
- 94 SHOP MANUAL
- mtx/quaife vhs training tape
- 2 x rubber seals that go into the upper steel backing plate that the cams protrude out in front of the motor
- 23k oil pump 3.2 motor
- BRAND NEW SHO "OLD STYLE" Style spark plugs .. agsp32pp 10 AVAIL ( STILL IN THE BOX)
- HEAD RESTS tracs PARTS
- oil pan bolts
- 2 half shaft seals
- fuel injector seals (injector to block seal)
- water pump halve seals
- new t stat o ring seals
- e brake pads new
- throttle body and maff air sensor
- new head gaskests 3.0
- 3 coil packs
- 1 used sets of valve cover seals
- 1 early model alternators
- custom made subframe holder … makes taking a tranny out a 1 man job easy! Fits in floor jack
- 4 various size sway bars
- custom made engine support
- box of misc valve cover bolts
- misc box of sho bolts when u “ loose the one you need!”
- misc parts for 3.2
- 2 x 3.0 crank pullies
- snap-on bearing puller
- helicoil set for cam bearing sleeves a must when taking cams out esp if you strip the threads on the cam bearings
- assorted timing cover bolts
Good hunting !!!
Bizzy
Bump for a great seller with a bunch of parts. :)
mfuld
Tulsa
I think my DIS is crapping out on me. Do you have any you know to work?
yamahaSHO
E85 whore
Arkansas
I'm interested in the main shaft as well as possibly the transmission.
1badsho
Port Charlotte Fl
Heres a partial list of whats for sale.
Note that most if not all the seals and new bolts etc … in poly bags from Ford are now discontinued and obsolete.
I have already gotten a lot of response and some parts might be sold. I will start listing those components sold by deleting the picture in my photo bucket.
The link to my photo bucket has all prices as well … just click on the link.
Buyer responsible for shipping charges and I took this into account .. especially the MTX tranny that would have to be trucked to where ever.
Enjoy !
- 400 + shim collection and tools too boot !!
- 93 shop manual
- 94 shop manual
- 60k and mtx/quaife vhs training tapes
- mtx tranny in good shape
- tranny plastic sleeves
- main cluster of gears almost new
- 1st and 2nd gear syncros like new
- sho shop jrs pressure plate and Rochester performance puck clutch .. used but in good shape
- thexton brake bleeder/o2/map/ign tester etc
- head rest tracs
- new old style spark plugs .. agsp32pp 10 I believe in the box
- oil pick up gasket to block
- oil pan bolts
- oil cooler to block gasket
- oil sending unit gasket to oil pan
- front main crank seal
- rear main crank seal
- ½ shaft seals 2
- rod bearing set from ford
- exhaust manifold studs 4
- water pump ½ seals
- oil pump to block seal
- new t stat
- iab valve new
- upper timing cover
- lower knuckle bolts
- e brake pads new
- cam seals (6)
- reinforced front motor mount
- 3 coil packs
- used sets of valve cover seals
- 3 ½ shafts drivers side non abs
- 2 early model alternators
- new pressure plate bolts
- misc tensioners for alt and pwr steering pump
- rear main seal installer
- 2 3.0 crank pullies
- misc gauges fuel pressure/compression/oil pres and water temp
- 10 differential bolts with loc *** from factory
and more !!
Any specific questions just email me at
[email protected]
payment via paypal
dond
38SHO
#1 Oil Abuser
North Palm Beach
got any valve cover bolts with good seals... and how many?
and how much
maybe local pick-up
how much are your shims if I buy up a good bulk amount..... shoot me a PM and we can talk, I could drive over there in a couple weekends and pick some stuff up if you want to unload anything... bolts all that type of stuff.... let me know
313tiger
