squeeks
svt cobra brett
SHO LOVER
FLORIDA
my front suspension has squeeks when just going over small bumps or making a turn does this mean that i need new struts or bushings or just ****
this car i just got it a month ago and want to fix it up..it sat for 6 months if that means anything
thanks brett
stephen newberg
Ladysmith, BC, Canada
It is most likely the end links, but it could be a number of other things such as the sub-frame bushings or the sway bar bushings. Lubbing will not help, but it is very unlikely to be the struts, so you are not looking at major costs to get rid of the sounds.
pax, smn
svt cobra brett
SHO LOVER
FLORIDA
pax, smn
thanks for your help
ill put it on the lift and check it out are the parts easy to get?? i see that you have your secondaires wired open does that help on a stock sho 97.the struts are still very stiff i was hoping that it was not them and no leaks either the guy i bought this car from said that he put new struts on 30,000 miles ago..
thanks for your help and write me back on the wire job id like to know on that one
brett
stephen newberg
All of those parts are pretty easy to find OEM from a Ford dealer. Alternatively, Moog makes pretty good replacements for them, which some would consider to be better than OEM. Oh, I forgot, you might as well check the ball joints when you have the car on the lift, since these things all seem to go at about the same time. Murphy in action.
On the subframe bushings, I think the consensus these days is if you are replacing the front ones, use the same ones as for the back, rather than the different front part number. Apparently the back ones are better. I shifted all mine to solid aluminum, so I do not know this from personal use, but people I trust on it have indicated this to be the way to go.
If your struts have been replaced only 30K ago, you will be on them for a very long time. I am still on my original struts at 155K, and they are working fine. But I think I have been luckier than most and doubtless will have to replace them in the not too distant future.
Wiring open the secondaries works the same on all Gen III years. It does not really seem to do much in the way of actual performance gain. Nor does it appear to effect gas milage. However, it can be considered as preventive maintenance since the IRMC, which opens the secondaries, is a frequent breakage part and is expensive to replace. Since it appears to make no real difference to have it out of the system entirely and the secondaries always open, many Gen III owners have gone that way. It also, if you like a bit more noise, gives an increased air induction sound from the motor. I personally consider that a negative, but I think I am in a small minority that way.
If you do wire them open, be sure to also disconnect the grey plug to the IRMC box so as not to generate a Service Engine code and to also to remove power from the motor there that pulls the cable that would open the secondary butterflies.
pax, smn
svt cobra brett
SHO LOVER
FLORIDA
pax, smn
so ill go ahead and repl all subframe bushings and swaybar bushings while
im under there and im looking to put exhaust on it as well and i have a set of flowmaster mufflers off my 03 cobra i think ill use.. will they sound good and do you know anybody that put super 40's on there sho the ones i have are 2.5 size and the inlet and outlet are on the same side.this car was once a victim of a cam failure at 133,000 miles and the used engine he got out of a place in georgia that he put in has 66,000 miles on it and i have not yet checked to see if it had the cam's welded yet...what do you think the chances of this used engine already having the cams welded...your thoughts!!! should i just take the cover off and see or just say f..k it..i olny paid 1,500 for this car and it is in avg shape w/no rust at all and good silver paint.new a/c and new radiator w/waterpump and rear main seal..the tranny is orignal and the speed sensor switch is bad so i have to shift it from 1st to 2nd when i take off then its fine but if i dont do that it will go from 1st to 2nd then to 1st again and i dont want to screw it up i just have to get it to the tranny shop and get it fixed...have you ever seen anything like that before and the speedo jumps around like crazy when you floor it
thanks brett :thumb:
Ian Macoomb
Ottawa, Ontario, Canada
If it's sounds like a squeaky hotel bed check the SARC sensors. Mine have squeaked since I bought it 4 years ago. I would disconnect them and see if the squeak goes away.
stephen newberg
I had a little such noise from mine, but I just took them off, cleaned them, and re-installed with a good dilectric and now its gone. Give it a try, Ian.
pax, smn
svt cobra brett
SHO LOVER
FLORIDA
pax, smn
where do i start??
brett
svt cobra brett
SHO LOVER
FLORIDA
im new to this ...where do i start
thanks brett :wave:
Ian Macoomb
There's sensors that attach to the suspension. The number you have is dependent on the year of the car and what Ford felt like putting on the car. My car has sensors on all 4 corners. Paul Nimz's car has 2 or 3 and it's also a '97. Go figure.
If you jack the car up and have a look you'll see them. You can't miss them.
svt cobra brett
SHO LOVER
FLORIDA
ok ill check it out and see
thanks bro
brett :lol:
