squeek and clunk sound
xpnsiv93
Corrupt state, IL
whenever i turn the steering wheel...just started w/the clunk but the rubbing sound has been there since it was lowered....clunk comes from driver side and is noticeable when turning left...i should stop racin it so much..probably my prob right???..Thanx for input SHOspecialists...i dont know enuf bout these SHO's but late nights readin bout them!!!
93redATX
SHOForum O.G.
WI
First of all, stop beating on an already broken car. That's a big no no. As for your rubbing sound, is it more of a groaning, or does it sound like rubber on metal? If it's rubber on metal, chances are your strut mounts are shot. Speaking of the struts, the KYB's probably won't last too long with Intrax springs. How long have they been installed on the car?
As for the clunk, there are a few different things that could be. I'd jack up the car and check out your driver's side suspension. Look at your tie rod end (this would be a creaking noise if it were bad), sway bar end link (this would definately give you a clunk if it were broken), and all of your bushings.
DHMag
Free At Last
InCahoots, Texas
not necessarily broken. the nut may have worked loose or the ball and socket dried up and made its own room to play.
aftermarket equivalants are readily available from your local auto parts stores, namely Auto-Zone and O'Riellys.
if the camber plates on the strut towers have been dislocated from their welds (done when obtaining additional positive camber needed on lowered SHOs), then its possible the strut mount is rubbing on the strut tower. i, as well, as a few other with lowered SHOs have this same sound.
other possibilities for the clunk are bad ball joints (only replacable via purchasing new lower control arm), a brake pad land (where the pads rest on the knuckle), loose caliper bolts (T40 socket used), or strut rod bushings have gone away and strut rods now hit against the subframe.
xpnsiv93
Corrupt state, IL
bad news
Well I know to expect bad news when it come to specific noises....car will be checked out while on jack stands next weekend and i will follow up w/my findings...as for the strut/spring combo..they were installed a couple months ago....Y what can happen w/that combo???...hopefully not bad things!!!...Im gonna have Performance Plus in Madison, WI(performanceplus.com) check it two times over while there!!!!!!...thanx for heads up!!!!!!!
DHMag
Free At Last
InCahoots, Texas
the strut (KYB) and spring (Intrax) combination you have wont have any negative effects on a daily driver. but for rough pavement, aggressive turns, even more aggressive speeds, youll notice ill handling charachteristics. the Intrax are linear rate spring (read - stiff) and the KYBs are "meant" to be factory replacements. but the KYBs fail utterly on the SHO, IMHO. the springs will wear out the strut very quickly. the only struts id recommend with Intrax springs are Tokico or Koni. other members here will differ in opinion.
before i moved to South Texas, i put new struts on my friends Blue92. he had KYBs with Eibachs for less than a year, less than 10K miles. when i removed the KYBs and placed them upside down (strut rod on concrete), i could place one finger on the bottom of the strut and barely push on it before it would start collapsing. there was no life left in the KYBs, except to be used for maybe the Koni inserts, if they could be used.
the strut/spring combination i am running, (and the first to try and succeed) is the Tokico with modified Moog Cargo (control) Coil springs. i drive aggressively and love the twisties. with my setup, i have little body roll. if i were to install subframe connectors, i would have zero body roll, just like SHOMurphs SR-69. NotSoSlowSHO (Kenny) is running modified Moogs on Monroe struts and he loves the ride. i consider Kenny and i to be pioneers in the Moog spring territory for the SHOs. we both did a lot of research and took a risk, and we both came out very pleased.
MilTownSHO
Horicon, WI
:rofl: :rofl: :rofl:
Ok but seriously folks, the first thought in my head was rear subframe bushings, since it's only when turning... :confused:
xpnsiv93
Corrupt state, IL
I hate
discovering a GREAT website (shoforum.com)after having had things(i.e. struts/springs) paid for and installed to only hear bad things about the combo...but it's sumpin I'll have to deal w/for now until they **** out on me...since the car is really a weekend warrior, i hope they will do for now..and the darn car is goin on stands today...SORRY DAD....it's time to make sure nuttin serious is goin on w/my susp...THANX everyone for the heads up, i will check on everything recommended hear today...THANX AGAIN!!!!!!!!!
