sputters under medium to hard acceleration
Gerb27
Detroit
my gen 2 has been sputtering under medium to hard acceleration for the last 2 days. I thought I just had bad gas in there but after a fill up and a bottle of lucas fuel injector cleaner it is still doing it. Has anyone had this problem?
greenbeanmtx
King Skidmark
Waco Tx
Mine started doing this after i had driven through some heavy rain. I did the same thing you did and since no check engine light came on i didn't know what was going on. I pulled one of the spark plug wires on the front of the motor to find that it was full of water. I guess the rain got in there some how. So i sucked it all out and made sure it was dry and problem solved. Hopefully thats all your problem is. Good luck :thumb:
somedude_001
Western NY
same thing happened to my turboSHO on the way to pitsburg for a TCCA meet. rain = water in plug wells for me aparently.
Gerb27
Detroit
pulled the plugs and had oil in the wells. Still isn't showing a check engine light. Did notice a drop in fuel economy.
gtstang1967
BannedInBoston
New Bedford,MA
what i use to do when my atx had oil in the wells was i would disconnect my dis pull the plugs out of all cylinders. put a rag in each and crank till the oil was gone. then clean the plugs and put them back in. connect everything back up. but a 60k is probally in order for you or at least plug well seals.
Gerb27
Detroit
How much do you should I expect to spend on a 60k for my MTX? I will be doing the work myself more then likely.
