Spring Comressor at Eastwood
jelloslug
Digital
Greenville, SC
Since it says specifically not for use on MacPherson struts I would not use it on them. Either it does not clear or some other feature about it makes it not safe to use on them.
tommyturbo
California
the ones we used on my suspension last weekend, looked exactly like those, and worked fine. Just slow to do with hand tools.
Rubix
I used a set of those on tired old stock SHO springs and they were starting to bend and made me nervous. I got beefier ones after doing one spring.
frosho
WOLFMAN
Tyngsboro, MA
Our strut/spring assemblies are MacPhersons, so the one you linked to isn't the right one.
This is what you want: http://www.eastwood.com/kd-tools-3387-macphearson-strut-spring-compressor.html
It's the exact same tool that Autozone rents out. I used one when I overhauled my suspension in 2010. It worked, but it was a pain in the ass at times. Once the springs start to compress, the spring seats can get in the way of the tools so you can't get a socket on them. I also had trouble compressing the stock rear springs far enough to take the load off the mount. I managed to get it done, but I don't remember if there were any tricks involved.
I've replaced my front strut mounts again since then, but this time I used Kirk's bench-top compressor. It's a helluva lot easier to use. Looks sorta like this except it's mechanical, not hydraulic:
Mike, the first one you linked to is exactly like what I use, and it works. it is also available from harbor freight for way less than the eastwood price.
jayro
Auburn, In
Autozone has spring comp for free with their lend a tool program. Its what I used when I did mine. If I did suspension alot I would probably invest in one, but for the occasional swap its hard to argue with "Free".
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Yea I got one of those.... just gotta make sure its on there right. Those little clips help. Gotta adjust and readjust a bit. Let me know. Is this for work on the red one? lol LMK how that goes.
Phoenix
SHOHOLIC
QC , Canada
Harbor freight , 10$
one finger or 2 , doesnt matter.
I used the 'long bolt' ones ONLY on macphersons , I donno why they tell you that you cant....
