SPOUT Connector/circuit
SHODOGG
Crowd Control
SHOCAGO
Does anyone know where this thing is located? I got codes 213 and 219 when I checked the codes the other day, 213 is "SPOUT Circuit Open" and 219 is "SPOUT signal defaulted to 10 degrees BTDC / SPOUT circuit open". Anyone know where it is or have any pics of it so I can see if theres anything in fact wrong with it? Thanks.
rangerj
Brunswick, Ohio
SHODOG220,
"SPOUT" = Spark Output of the ECU (Electronic Control Unit)or (DIS) Distributorless Ignition System.
Sounds like you have a connection or wire problem in the DIS system. To check the DIS system see my posts within the last 10 days or so. It will give you the test proceedures. rangerj
